Need HELP regarding graphic card
kd166
130
Hello everyone,
Well this is my second question because my first thread was closed, which was my bad fr some reason... i needed to knw more reviews abt the graphic card upgrading my NVIDIA 9800gt
My budget wud be around 22K(INR)
My current computer spec:
processor: amd phenom 2 x4 965 BE
RAM:4gig ddr3
psu:corsair tx850v
mobo:ASUS M4A785TD-V EVO
gpu:9800gt
well i was planning to get one of these GPU'S:
http://www.flipkart.com/sapphire-a [...] query=7950
http://www.flipkart.com/msi-nvidia [...] uery=660ti
http://www.flipkart.com/sapphire-a [...] 354bd98008
one more question, do i have to upgrade my processor and mobo if i am upgrading my gpu ?? Does these link with each other ??
Thank you !! :)
get the 660 ti.
this is because both having the same performance and considering the 660 ti is cheaper it is the better value for money product.
however if both were same price i would go for 7950.
jaideep1337
479
Go with the Radeon 7950 as it offers the best performance for the price. Also you don't need to upgrade your CPU or your motherboard as they will both support it although there will be a very slight bottleneck because of the CPU.
I cannot see anyone spending $300 on the graphics card and then having $1000 for the monitor(s). Can you?
At 1080p, GTX 660 Ti is not slowed by its memory bus. The high memory clock makes up for it, making memory bandwidth similar to HD 7870. And overall, it's similar performance to HD 7950.
Lastly, GTX 660 Ti can be also overclocked - but when making recommendations, you should never depend on overclocking - it's never guaranteed to work.
mohit9206
get the 660 ti.
kd166
130
Alright so both are like same.. they give the same performance... but why the price is high for 7950.. and suggest me any other card which comes under 22k that would be grateful....
kd166
130
I need a graphic card which can support games for next two years ....
GTX660 will do that easily. Question is whether it's important to you that you have two years of gaming at max settings, or if you'd be happy to use medium/high instead of high/ultra? To be able to play everything on ultra at 1080p, you'd need a GTX670, which is out of your price range, and that's just for today's games (though most games would be fine maxed on a GTX660). If you just want to be able to play them at decent settings, GTX660 will serve you well.
And GTX670 better still :) While GTX680 would be a waste of money. Honestly, until recently I'd say GTX660 is the way to go, but Far Cry 3 on max and 1080p AA really gives it a kicking. The GTX660 is a superb card, but unfortunately it's no longer possible to say it'll handle anything at 1080p. For that, GTX670 is the minimum now. And with GTA5 and Crysis 3 coming up, it's soon gonna be more games than just Far Cry 3. As usual, the more you spend, the better it is (though the GTX680 really isn't worth it for the framerate gain).
