Need help regarding Sketchup
ARshack
8
So yesterday, I downloaded Sketchup and I am having some problem in Installing the Software.First thing first, the installer is in Russian language and I am only able to understand a part of it. It shows some error regarding Windows update, says to check for updates and when I do that, the system checks for sometime and then says "Failed to check for updates". Secondly, It says to install some kind of fix like KP29012 whatever, I downloaded it from a third party source and it says, This update is not applicable to your computer. How do I fix this?
Latest posts
