G
Guest
Guest
Archived from groups: comp.sys.hp.hpux,comp.sys.hp.hardware (More info?)
I am having a heck of a time trying to discern what is wrong with one of my
K100s
When attempting to install HP-UX, the system boots, but eventually displays
the following on the console:
Booting...
Boot IO Dependent Code (IODC) revision 0
HARD Booted.
ISL Revision A.00.43 Apr12, 2000
ISL booting hpux (;0):INSTALL
Boot
: disk(8/12/5.2.0.0.0.0.0;0):INSTALL
9707284 + 1122304 + 691712 start 0x14d568
FLT CBFB
******* Unexpected HPMC. Processor HPA 0xfffa0000 *******
GENERAL REGISTERS:
r00/07 00000000 0010C800 00452F94 02A46800 00000089 00000000 00000000
02971280
r08/15 00000001 00000002 00000003 0FD1BE2C 0014D568 FFFFFFFF 00000801
000331D0
r16/23 00000001 00030720 00000008 FFB40838 00000008 00000001 00081003
FFB40800
r24/31 00000000 00000045 FFB40845 00A73268 00000000 00000038 7FFF0CB0
00081003
CONTROL REGISTERS:
sr0/7 00000000 00000000 00000000 00000000 00000000 0000224D 00002247
00000000
pcq 00000000.0010CF84 00000000.0010CF88 isr = 00000000 ior = 00452F94
pid1/4 0000 0000 0000 0000 ipsw = 0004000F iva = 00029800 sar = 0F ccr = C0
tr0/7 00982AA8 00035800 FFFFFFF0 00000000 01830930 15F168E5 0009BB68
7FFF0BB8
rctr = 00000000 itmr = 160B5F84 eiem = FFFFFFF0 eirr = 80000008 iir =
E840C002
cr1/7 00000000 00000000 00000000 00000000 00000000 00000000 00000000
MACHINE CHECK PARAMETERS:
Check Type = 20000000 CPU STATE = 9E000004 Cache Check = 00000000
TLB Check = 00000000 Bus Check = 0020000C PIM State = ? SIU Status =
Detected by 00000000 Assists = 00000000 Processor = 00000000
Assist ID = 00000000 Slave Addr = FFFA0000 Master Addr = 00000000
trap type 1 (HPMC), pcsq.pcoq = 0.10cf84, isr.ior = 0.452f94
@(#) $Revision: vmunix: vw: -proj selectors: CUPI80_BL2000_1108 -c
'Vw
for CUPI80_BL2000_1108 build' -- cupi80_bl2000_1108 'CUPI80_BL2000_1108'
Wed N
ov 8 19:05:38 PST 2000 $High-priority machine check: (display==0xd910,
flags==0
x0)
* CPU State 0x9e000004
* Detected By 0x0
* Bus Check 0x20000c
* Slave Address 0xfffa0000
WARN E000
*** A system crash has occurred. (See the above messages for details.)
*** The system is now preparing to dump physical memory to disk, for use
*** in debugging the crash.
ERROR: Your system crashed before I/O and dump configuration was complete.
A crash dump cannot be taken under these circumstances without
special configuration. Contact your HP support representative.
Can anyone make heads or tails of this?
Thank you all very much, your help is greatly appreciated.
K100s
Booting...
HARD Booted.
Boot
FLT CBFB
GENERAL REGISTERS:
02971280
000331D0
FFB40800
00081003
CONTROL REGISTERS:
00000000
7FFF0BB8
E840C002
'Vw
Wed N
flags==0
x0)
* Detected By 0x0
WARN E000
