Hello everyone hope your doing well! So i have a problem that i desperatly need help in. You see i recently on my rtx 3070 laptop ventured into fps and triple A titles. But i noticed that i would get fps drops like for example, overwatch 2 the game would run at full speed at the max fps right, while my temps and everything is fine then randomly it has a huge fps drop going from the hundreds to the 40-50s then it would go back to normal speed.
I tried reverting my drivers, i tried using ddu, i update everything on my pc, i checked my temps, i made sure my laptop is clean and has air, hell i ive done 2 factory resets. When it come s to any other game thats locked at a certain fps i dont get any problems. Ive heard from a person who responded to my reddit post on the teahcsupport sub saying that this update had some sort of glitch.
I made a 6 min video showing the problem i have while using msi after burner. Note it runs better than in the video since ive done a clean install. but it keeps the 144fps longer and still has a major frame drop.
View: https://youtu.be/-CtyX__fYVw
I wanna know if anyone is experincing the same thing or has a solution to this problem ?. My laptop specs is down below. I wasnt able to get any help so im using this site for the first time.
Thank you for reading.
Fyi i only had my laptop for a month brand new and it worked great till now.
Laptop specs
Laptop specs
- Processor12th Gen Intel(R) Core(TM) i7-12700H
- Number of Cores20
- Speed4.6 GHz
- Video Card
- NVIDIA GeForce RTX 3070 Laptop GPU
- Total Menmory16 GB
- Dedicated Memory8.0 GB
- Operating SystemWindows 11
- RAM16 GB
