Need help selecting a case for my build ???
loganmason
62
I need help selecting a case for my build. The case must be a Mid tower, have a side tower window, also have USB 2.0 / USB 3.0 Audio front ports. The case must also be able to fit a 212 EVO fan/heatsink and a SAPPHIRE 100355OCL Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card OC Version and I would prefer to have blue LED fans as well. What do you think about a Rosewill PATRIOT Gaming ATX Mid Tower Computer Case, coating,support 13" (33cm) VGA card, come with Four Fans,up to 7 Fans, w/ Window Side Panel. Would this work or not. Thanks and all suggestions and recommendations are gladly welcomed. Thanks very much in advance
Looks good for you. Look this: http://www.youtube.com/watch?v=OqlVQMXihP0
If you want you can trow in 180mm top fan in that case!
Enermax have really nice led fans 120,140 and180mm
http://www.enermax.com/home.php?fn=eng/product_a1_1_1&lv0=4&lv1=32&no=147
http://www.enermax.com/home.php?fn=eng/product_a1&lv0=4&lv1=40
Look if can find fan controller.
This looks goodnew case too. If you want look something else :)
http://www.bitfenix.com/global/en/products/chassis/ronin/
http://www.bit-tech.net/hardware/cases/2013/08/09/bitfenix-ronin-review/1
http://www.anandtech.com/show/7158/bitfenix-ronin-case-review
