Question need help selecting a laptop/ultrabook
Apr 16, 2019
Looking for a good laptop for work.
M.2 SSD, newer generation Intel CPU, Good keyboard, stylish, very slim, around 15'' screen.
Will be used for browsing, Microsoft office, a little bit of photoshop.
Budget: Around 1000 Euro.
7
go for a slimmer laptop (14-18mm) which is a fashion nowadays... ci5 or AMD R5 works great for you... under 1000E you will find plenty of good stuff... i would recommend you don't go for 15.6 laptops as thet are heavier... 14 and 13.3 are very good choices
Apr 16, 2019
Thanks for the reply Mowaisshahid. 13.3 will be a to small a screen.. 14'' might do.. is there any specifik models you can recommend?
