Need help selecting a motherboard.
MrDitorix
21
Hello, I am currently in the process of purchasing parts for a budget pc build and have reached a stopping point because I have realized that my motherboard that I was about to purchase is not compatible with the APU I have already purchased (AMD A10 5800K), and I am now having trouble finding a compatible motherboard that stays within my budget. My budget for a motherboard is around 60 USD, very tight budget as you can tell. The motherboard needs to be compatible with the AMD A10 5800K,
and I would like for it to support at least 8gb of RAM. I would like to thank you for taking the time to read this post and would like to thank you agian if you are able to help me find an appropriate motherboard considering my budget.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130753
This is motherboard that I think is compatible with the APU, but I am not 100% sure.
Similar threads
