Need help selecting a motherboard
I will choose B150M-D3H. G1 Sniper B7 & B150M-D3H spec is the same. just different power phase , PCI-EX1, printer port. so B150M-D3H is better & cheaper. and don't consider H170 chipset.
Reply to Mr. KAgouris.
I didn't mind the form factor because I am getting a big case. I just want a quality build motherboard that will last a while before replacing.
Hey kagouris and alston. What did you use to compare the motherboard. I use motherboardbenchmark.net but I do not know if they are bias or if it is accurate.
Well, the specs and experience? Motherboards do not affect performance in any way (at least when you don't overclock) so the difference is in features. Also, higher end models tend to be higher quality (e.g. longer lifespan, better shielding for the audio circuit, higher quality components used on the board).
