Hello,
I have an older Dell Dimension 9200 that I'm trying to use a media center. It's been working fine directly connected to the TV with computer speakers on the side, but I've recently purchased a home theatre system and I'd like to get the computer to send audio and video information through an HDMI port (right now I'm using a DVI to HDMI adapter). So I'm looking for a graphics card with an HDMI port that will allow my computer to connect easily to my home theatre system.
As far as I know I need a card with a PCIe x16 connection that will work with a 375W power supply.
My CPU isn't amazing, it's a dual core with 2.4GHz. I read somewhere that a slow CPU is not good for higher end graphics card.
I've also read that I may need a BIOS upgrade from Dell in order to use a v2.1 card? ( http://answers.yahoo.com/question/index?qid=20120402095546AAum01E ).
If anyone can help me out by pointing me in the right direction of a suitable graphics card I'd really appreciate it. It was a confusing task to gather than information alone, now I'm just completely lost when selecting a card.
Thanks!
- Nick
Thanks!
- Nick
The newer graphic cards come with audio over HDMI. Back when I had a 8800gts the 320mb model I had to use a HDMI header on my motherboard and I had a little cable to connect to get audio from HDMI. Newer cards not so much anymore
