Need help selection parts for water cooling
Will_63
31
hello everyone, i am currently switching pc cases and along with the swap i want to add a GPU cooling block into my loop along with an upgrade from soft to hard tubing.
my parts relevant to this are an Asus GTX 1080 strix and the water cooling components are everything included in the EK-KIT X360
kit parts :
-universal CPU water block EK-Supremacy EVO ,
-water pump: EK-DDC 3.2 PWM Elite Edition,
-radiator: EK-CoolStream XE 360 (Triple),
-reservoir: EK-RES X3 150
My main problem is finding a GPU block that doesn't cover the liquid but that is also compatible with my card.. along with getting the best (most durable and least likely to bleed any chemicals into loop) hard tubing type and making sure everything fits/ is compatible.
in this picture ill show you what i mean (this is a GPU block that covers the liquid and is one that i would not like to buy)
ek-fc1080-gtx-strix-nickel
https://www.ekwb.com/shop/ek-fc1080-gtx-strix-nickel
this is one that i like and want to buy but is not compatible
ek-fc1080-gtx-ftw-nickel
https://www.ekwb.com/shop/ek-fc1080-gtx-ftw-nickel
additional information: the new case is the thermaltake core p5 tempered glass edition
ideally if someone knows which tubing is the best and knows which fittings i would have to buy along with where i could buy the GPU block im looking for, that would help me tremendously
thank you to anyone who took some time to try and help!
PS if anyone knows whether or not theres a GPU block that is compatible with the asus gtx 1080 strix and the 1080 ti strix that would be the best block for me!
