I was looking for some suggestions as to how I should set up my Network. I've just purchased two Asus RT-AC68U routers which should be arriving in the next few days, I've read numerous forums on setting up this router but each thread contradicts the next...
What I have is an older German house with concrete walls and floors, modem/Router is on the second floor in the office. I have an older linksys wrt54g (can't believe this thing still works) router in the workshop hooked up to the modem Via Ethernet and a D-Link DGL-4500 in the living room on the 1st floor hooked up via Ethernet. Currently the D-Link has been rebooting under load... currently I have a separate wifi ssid for each device. port forwarding is enabled for the ps4.
What I would like is one wifi ssid for the entire house and shop, the modem will have the routing capability disabled and one of the asus Routers will take its place, the second Asus will be in the living room and the linksys will stay in the shop.
I am looking for the best setup for the 3 routers, in a way that the routers will be running at optimum performance with the largest range possible, fastest speeds in the vicinity of the router and without having to switch to a different wifi while moving throughout the house and shop... if possible. Any suggestions?
