Hello!
I am currently in Sri Lanka and here, the most common type of Internet solutions are these 4G CPE indoor / outdoor sets.
I have an ASUS AC1300 (from the US) I was wondering if it is possible to use it with this type of set up?
I would prefer not to use it as a "repeater" but if that is the best solution I would be open to instructions on how to do that as well.
The exact model of my Provider supplied Hardware is this 4G CPE ZLT P11 set(outdoor + indoor )and I have the ASUS AC1300
I am not going to lie. While I am pretty advanced with most things digital and have been for many many years... Networking has always been a blindspot for me.
I am a bit confused in this particular use case if I can plug directly from the outdoor antenna into the ASUS as the Tozed brand Router seems to be just that a router and not a Modem ( I could be wrong) and in the states I always had a Modem to Router config so this is throwing me a bit of a curveball PLUS it would appear that few people actually use their own gear here as broadband is still a luxury item.
Any tips, instructions, pointers or even advice as to what type of workflow I should be searching for would be helpful.
Thanks!
Thanks!
