Need help setting up Logitech z506 speakers
ItsAlwin
I bought the speakers today, I set all the cords in the right areas but only have 2 speakers that work, the 2 rear ones. I can't get the center, subwoofer, or other 2 speakers to work. I have tried changing the cords around and it has only switched which one of rear and main speakers it would come out of. Now when I plug in the speakers, it shows that nothing is plugged in.
I put the colors in correct, my windows doesn't have the same colors so I mirrored it the same way from how it is plugged into my subwoofers. Not sure if I did, it doesn't give me the option anymore because everytime I plug it in, it says that there aren't any speakers plugged. I am pretty sure I am plugging everything in correctly.
