Hey guys, recently got a faster line so I wanted to upgrade my infrastructure a bit too. My main modem (so the modem that accepts the connection from my ISP) is an Arris TG862. It has no QoS and is mainly used as a switch and a DHCP server. The second one is an Asus RT-N12+, which acts as a wireless router + a QoS client for the devices connected to it (it is connected directly to the Arris from the Arris´s LAN port to the Asus´s WAN port). The Asus also has DHCP enabled, but hands out addresses on the second subnet. Downstairs, I have a TP-Link TL-WR940N, which acts the same as the Asus and is also connected directly to the Arris on the WAN port. The TP-Link also has DHCP enabled, but hands out addresses on the third subnet. Now here is the problem. I have read all over the internet that DHCP should only be enabled on one router. I have tried this and I have run into many problems (I did mostly try it with the Asus). First, if I switch off Asus´s DHCP, the router becomes inaccessible and I have to reset it in order to get into its settings again. I tried changing the IP of the Asus to the same subnet as the Arris before switching off DHCP and it sort of worked. I could access the Asus´s settings and all connections went through just fine, but in the settings, it said that the internet cable isn´t connected (which it was and the connections went through fine) and the QoS applied on the Asus just didn´t work. It recommended I should switch to AP mode, but that doesn´t support QoS so it isn´t an option. What do you guys think I should do? Is having three DHCP servers on three different subnets really that bad?
Thanks for any advice
