I have been searching everywhere to try to piece together heat output for the individual components I plan to use, to figure out what size radiator I need. I plan on cooling a E8400 CPU, dual 8800 GTS's G92"s, and the NB, and possibly the hard drive but more than likely not. I am using the inwin F430 case so its a smaller case. I think I have figured out how to fit a swiftec MCR220-QP with the res. inside the case, but will that rad be able to dissipate the heat in one loop? or should I use two loops with the CPU and NB on a MCR120-qp? I want to try to keep everything inside the case or at least one radiator attached to the back. I will probably OC the graphics card more, with a medium OC on the CPU
