So I built my own PC maybe a year or two ago, enjoyed the experience and so far everything has gone well. The only issues I've had are:
A) When I shut down my PC sometimes it will restart instead of staying off. I've read up and heard it may be that the computer is experiencing an error on shut down and that's why it is coming back on. Anyway, it was never something that bothered me, but thought I would mention it in case it could help solve problem B which is my main issue.
B) While I'm using my computer, seemingly randomly, my computer will have small (maybe something like 1-2 second) freezes sometimes half an hour apart sometimes it will never happen in a sitting. To give more detail, the freezes occur sometimes when I have been on the PC for a while or sometimes just after start up. It can depend.
Things like YouTube videos and music still run during the freeze, but if i'm typing for instance and I happen to be pressing a certain key then it will be like i was holding down the key, producing multiple of the same letter until the freeze is over. The freeze also effects the mouse cursor. If I am video editing and playing the sequence, the playback will run like it is in fast-forward until the freeze finishes.
Again, this issue is something that I think has been around for months (I can't quite remember to be honest when it started which sounds silly, I know, and I can't remember if it's been here since the initial build) and it hasn't bothered me up until now. However, I've started recording game play footage while doing voice over using Audition, but I'm finding when it comes to editing that the voice over has points in it where the program has seemed to freeze for a second and so the audio cuts out there for a second and then continues as normal. This leaves my voice over and game play out of sync for the rest of the video if left unedited. So, I'm linking these stutters in the voice over perhaps to this stutter issue.
Please, if anyone helpful could give me a hint as to what might be causing the issue I would really appreciate it. When checking open hardware monitor all temperatures seem to be reasonable and when looking at task manager I'm not seeing any CPU spikes when the freeze occurs, so not sure where to look. Thanks so much for reading my essay 😛.
Hardware specs:
430w EVGA PSU
Gigabyte H81m-S2H Motherboard
Core i3 4160 CPU
Hyper X 4gb Memory 1600mhz
GTX 560 TI GFX card
SanDisk SD7SB6S128G1122 SSD Boot drive
1tb hard drive that I can get the model number of if it is needed.
Hardware specs:
430w EVGA PSU
Core i3 4160 CPU
GTX 560 TI GFX card
