Hi I am reaching out for some advice and help regarding a new custom build I received from ibuypower.
The pc arrived with some shipping damage and long story short the motherboard is damaged. I am able to power on and use the pc but the integrated wlan/wifi is dead. I contacted ibp yesterday and they recommended a motherboard replacement although I am not excited to mail the pc back and forth given past problems. I asked for them to send me a replacement motherboard and they will not unless I send the whole pc back.
I am considering just purchasing a new motherboard and doing the install myself. However I am a bit nervous on what motherboard to buy given this is a windows 11 os. Can anyone help? Below is the system details. Thanks
Processor | AMD Ryzen 5 5600X Processor (6X 3.7GHz/32MB L3 Cache) |
Processor Cooling | iBUYPOWER 240mm Addressable RGB Liquid Cooling System - Black |
Memory | 16 GB [8 GB x2] DDR4-3200 Memory Module - ADATA XPG SPECTRIX D41 (RGB LED) |
Video Card | NVIDIA GeForce RTX 3060 Ti - 8GB GDDR6 (VR-Ready) |
Motherboard | ASUS PRIME B550-PLUS AC-HES - WiFi, ARGB Header (2), USB 3.2 Ports (1 Type-C, 3 Type-A), M.2 Slot (2) |
Power Supply | 800 Watt - 80 PLUS Gold Certified |
Advanced Cabling Options | Standard Default Cables |
Primary Storage | 1TB WD Blue SN550 M.2 PCIe NVMe SSD -- Read: 2400MB/s; Write: 1950MB/s |
Sound Card | 3D Premium Surround Sound Onboard |
Network Card | Onboard LAN Network (Gb or 10/100) |
Operating System | Windows 11 Home - (64-bit) |
