Need help switching to a new monitor on my PC
pmarsh11
15
So I have been working on this all day but no luck. So I had a sylvania tv as my monitor for my Lenovo k450. That tv was a piece of junk so the resolution was way down. I have a Vizio tv that works pretty well as a monitor so I decided to use that, so I put the resolution up to where it has to be to run the Vizio. But when I plug the HDMI into the Vizio, the Vizio just says "not support" yet it still works on the sylvania. I think my main question is how to make the Vizio "screen 1"
pmarsh11
15
its a tower, and the video card is made by NVIDIA. its a gtx635 (i need to get a new one soon)
pmarsh11
15
Really no resolution is working on the vizio. I'm trying to use 1920x1080 i think… but lower resolutions didnt work either.
pmarsh11
15
no the vizio doesn't show up at all because i never have them both plugged in at the same time cause my computer only has one hdmi port and i don't have a VGA cord. But when i plug the vizio into the computer and it says "not support, it might be showing the vizio as #1 or #2 but i can't tell cause i can't get the display to show on the vizio.
pmarsh11
15
The video card has a hdmi and a vga and both tv' have an hdmi and a vga
pmarsh11
15
Yes I ordered a vga to hdmi adapter in the mail it will be here tomorow. Do you think it will solve the problem?
pmarsh11
15
its the second one but i also bought a hdmi male to hdmi female cord.
pmarsh11
15
but my computer has a male vga and the adapter is a female vga (so it will fit into the video card) to a male hdmi. Then i bought a female hdmi to male hdmi cord, so the female end can go into the male end of the adapter, and then i plug the hdmi cord into the tv...
pmarsh11
15
Okay I just picked up a vga cable...
What should I do now?
Edit: okay so the screen works using a vga now, but with hdmi it has the same problem...
pmarsh11
15
