So basically this happens almost every time I reformat my rig, it won't automatically detect my GPU on PCIe slot and I just wait a couple of days for it to do so but now I just want to know a real fix for this problem.
The GPU's fans are running. The system detected the GPU couple of hours after the fresh reformat of the system, I had already installed the up to date drivers prior to the system detecting the GPU because my set-up has on-board graphics. After a few hours my display froze and when i rebooted the desktop it opted back to the on-board graphics.
Things i've tried:
1.I've tried disabling the on-board graphics through the bios, when I do this and boot the set-up I get that post beeping noise indicating error in display. So I have to reset my CMOS to restore the default bios again.
2.I've tried pushing down firmly the GPU to confirm if it really is connected properly to the PCIe slot, but since the fans are running I'm pretty sure they are. Plus i've removed and inserted it back a couple of times already.
3.I've tried the DDU program a couple of times already, in past cases this has worked for me but it usually takes a couple of days of back and forth of uninstalling and installing drivers.
My Specs:
CPU: AMD A6- 3500 APU (onboard graphics Radeon HD 6530D)
Mobo: GA-A75M-UD2H (bios are up to date)
GPU: R7 250 DDR3 2gb
Memory: 2x4gb (1600mhz)
PSU: 550w (I forgot the brand but its not generic)
Display: AOC 19" VGA
Things i've tried:
My Specs:
