Hi guys i bought a desktop awhile ago, I'm in need of some advice since i'm not a technical guy,
I bought the pc ready built, And i have added hardware, I added a extra 8gb ram and H80i CPU cooler and a AMD-8350 cpu So i wam kind of concerned about my PSU is it good and is it reliable? I want to start upgrading for a SSD, Gtx 780ti But will i also need a new motherboard for the 780Ti?
My pc specs are as follows:
Cpu AMD 8350 BLACK EDITION
Graphics card : Nvidia GTX 660 TI 2 GB PCI-E Graphics Card With HDMI
Motherboard: gigabyte 78lmt usb3
Ram 16gb corsair Low profile DDR3 1600MHZ
Power supply
750 watt
Atx 12 v compliant for all typers of CPu and mother boards.
Dual 12v Rails
12cm silent fan.
PCI, SATA and 20+4PIN
And thanks! Also my computer case is the Cooler master CM STORM
Power supply
750 watt
Dual 12v Rails
12cm silent fan.
, Ill start saving for all the parts since one of them is a gtx 780ti its pricey
