Hello all,
Im studying Master of multimedia design and im in need of a new PC for studying and future work. I'm not a hardcord in 3ds Max so Quadro cards properly wont be my choice. And I have some in my minds for some of the parts. Please look at my build below and let me know what you think about it and give me some feedbacks for the rest of the build.
Thanks for your time and feedback you can offer.
Budget Range: $3000
Are you buying a monitor: Yes
System Usage from Most to Least Important: VFX, 3D, Design
Do you need to buy OS: No (but which one should i choose - Window 7 Pro/Window 7 Ulti/Window 8)
Your Monitor Resolution: Maybe 1920x1080, but i need the monitor color to be good
Additional Comments: I would spend most of my budget on CPU, then monitor if needed to
Storage: HDD 2 TB
Storage: SSD 128 GB
Video Card: NVIDIA GeForce GTX 980 4GB
Budget Range: $3000
Storage: HDD 2 TB
Storage: SSD 128 GB
