need help to build my 1st PC
lasha7716
hey guys i want do you think about this built? http://pcpartpicker.com/p/mLLmBm I'm planning to buy components in Q3-4 2015 and might swap GPU for gtx 960 ti if it comes out.My goal i to build PC that will last for 3 years of high-ultra 1080p gaming and my budget is 650-700$.bad thing is that i live in georgia(country not state) so i can only buy things from amazon and can use great deals from newegg.also i'm not planning to OC because I don't know how that's why i went with this CPU and is there any cheaper mobo which will be good for rest of the build?
Great choice of PSU :)
You can't overclock that processor so look for a H97 motherboard; they're cheaper.
The Corsair RAM is probably a bit expensive too, any 1600Mhz, 1.5V CL9 Ram made up of 2x 4Gb sticks in a kit will do
Consider the R9 290, it will be cheaper than the GTX 970 but better than the GTX 960 for just a little bit more money
