Okay, here is build. Just click on the first link and it will take you to the PCPartPicker webpage with the completed build. Now this build does not have a video card (GPU) but you should be able to play those games with the integrated graphics (HD 530) of the i5-6500. The are equivalent of about an R7 240 so reasonable entry level graphics. By doing this I can give you a better base system that can be upgraded and added to later. Things to consider are:
- Solid State Drive (SSD). This vast improves things like boot times and screen switches during gaming
- The big hitter, a discreet (separate) video card. Adding a video card like a R9 380 or a GTX 970 will take this system to mid range gaming system.
- Additional ram. Right now the integrated graphics will use the motherboard RAM and you might find that things slow down, especially if you are doing more than one thing at a time. A discreet video card has its own ram (VRAM)
PCPartPicker part list:
http://pcpartpicker.com/p/dFGCjX
Price breakdown by merchant: http://pcpartpicker.com/p/dFGCjX/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($199.98 @ OutletPC)
Motherboard: Gigabyte GA-H170M-D3H Micro ATX LGA1151 Motherboard ($89.99 @ SuperBiiz)
Memory: G.Skill Ripjaws 4 Series 8GB (2 x 4GB) DDR4-3000 Memory ($51.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($46.89 @ OutletPC)
Case: Cougar Spike MicroATX Mini Tower Case ($33.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 430W 80+ Bronze Certified ATX Power Supply ($53.99 @ SuperBiiz)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($15.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit) ($87.95 @ OutletPC)
Monitor: BenQ GL2460HM 60Hz 24.0" Monitor ($129.99 @ Amazon)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($24.99 @ Newegg)
Total: $735.75
Generated by PCPartPicker 2016-02-05 10:12 EST-0500
