My components:
I7-9700k // EVGA GTX 1070 SC GAMING
2x8 Go DDR4-3000 G.SKILL TRIDENT Z
GAMMAXX GT RGB AIR COOLER
Carbide 175r RGB Tempered glass // 3x LL120 Corsair RGB Fans
Prime Z370-A II
Corsair 650w 80+ Bronze (CX650M)
I'm looking for advice for a corsair case. I currently have a bad cpu cooler and I want to upgrade it. I'm looking for a h100i rgb platinum but it can't enter on the top slot in my current case even tho corsair says on their website that it can. Here's another link that I made that shows the restrictions: https://forums.tomshardware.com/thr...ce-with-h100i-or-h115i.3642307/#post-22119050
Are there any atx corsair cases that could actually work with a h100i rgb platinum and my current setup? My pc placement is also restricted in length. The case cannot be more than 470-480mm long. The height is not a problem tho. I'm looking for a white case maybe. What would work?
Thanks!
Prime Z370-A II
Thanks!
