Need Help!! To Overclock AMD Sempron 145
Jitin Sharma
37
Hello
I need help to overclock my amd sempron 145 processer , its current speed is 2.8Ghz.
I want to overclock it 3.3Ghz or higher.
here are some specification
Processer - AMD Sempron 145
Mobo - Biostar N68S3B
Installed Ram - 2Gb
PSU Power - 550 watts
Please help me out !!!
Let me know if you want more details.
Thanx
Actually I am not trying anything to accomplish, just felt my pc need to be upgrade, but one of my friend told me to overclock it and unlock it into dual core which would save my money and will move to advance level.
thanx
Yeah it is possible to upgrade both RAM and Processor, but my first option will be overclocking both. If there is no way then i will move to upgrade both
Thanx for the help it will help me a lot while upgrading.
Cheers
Depending on your budget, a FX-8320 on a 990FX would do pretty well. If you are primarily interested in gaming, however, check the benchmarks. The FX does well in well-threaded games (e.g. some newer titles), but is beaten even by i3's in poorly-threaded titles. I'm not trying to create a raging AMD vs. Intel debate (I run both), but to point out that "one size fits all" really isn't true.
