Hey guys.
I am currently attempting to overclock my i7-9700k.
Here is my current specs:
CPU: Intel Core i7 9700K / 3.6 GHz
CPU Cooler: NZXT Kraken X72
MOBO: Asus Rog Strix Z390-F GAMING
GPU: Asus Rog Strix RTX2070 O8G GAMING 8GB GDDR6
RAM: Corsair Vengeance RGB 16GB: 2x8GB DDR4 3000MHz DIMM
SSD: Samsung 970 EVO Plus MZ-V7S500BW 500GB - PCI Express 3.0 x4 (NVMe) - M.2 Card
HDD: Toshiba P300 3.5´´ 2TB - 7200rpm 64MB SATA-600
PSU: Corsair RM750x
CASE: NZXT H series H700i Window Black
Attempt 4.9GHz:
Multiplier: 49
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
SVID Support: Disabled
BLCK Aware Adaptive Voltage: Disabled
CPU Core/Cache Voltage: 1.350
Multiplier: 50
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
CPU Core/Cache Voltage: 1.360v
CPU Load-line Calibration: Level 6
CPU Current Capability: 170%
Long Duration Package Power Limit: 4095 (max)
Short Duration Package Power Limit: 4095 (max)
CPU Core/Cache Current Limit: 255.75 (max)
2nd attempt 5.0GHz:
Multiplier: 50
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
CPU Load-line Calibration: Level 5 (Changed)
Changes: Only changed LLC from Level 6 to Level 5.
So a few questions here.
I've heard/read that if a worker stops in Prime95, it means your overclocking is unstable. Is it worth trying to let it finish and see what happens or pointless ?
Also i noticed when using XTU, that every 10 sec, 1 or more cores drop to 4.7GHz for a split second and go back to 5.0GHz. Is that due to AVX instructions coming into play or is it my cpu throttling? And how to fix it if needed.
Temps are fine, hitting max 82c on 1 core, rest high 70's.
VCORE is at 1.360v and droops to 1.332v and never go over 1.360v.
Update on my latest 5.0GHz attempt:
I just tryid following:
1.375v vcore fixed, LLC 4. Vdroop to 1.305v and BSOD in Prime 95.
1.375v vcore fixed, LLC 5. Vdroop to 1.350v and BSOD in Prime 95.
1.375v vcore fixed, LLC 7. Vboost to 1.421v and BSOD in Cinebench r15. (No vdroop - Probably overshooted the voltages with Level 7 i assume)
I tryid LLC 6 together with 1.360v without success.
Im trying with LLC 6 now with a higher vcore voltage.
Settings:
Multiplier: 50
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
CPU Core/Cache Voltage: 1.380v
I removed all the other stuff i added earlier. (See above).
Did OCCT Linpack Non-AVX.
1.380v, vboost to 1.403v. No vdroop.
Max temp 94c.
Distance to TJMax 6c.
After 13min of OCCT i got BSOD.
I dont know what to try next tbh.
Is there ANYTHING I am missing or something i need to dial/tweak for 5.0ghz to happen? Or have i done everything correctly but my chip just won't hit 5.0GHz due to silicon lottery ?
PSU: Corsair RM750x
Attempt 4.9GHz:
Multiplier: 49
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
- Cinebench r15 - Passed.
- Realbench - Passed.
- Prime95 - Passed.
- Highest temps was 85c.
Multiplier: 50
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
- Prime95 - BSOD after 2 minutes.
2nd attempt 5.0GHz:
Multiplier: 50
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
- Prime95 - Worker stopped after 3 minutes, no BSOD.
- XTU - Passed.
Settings:
Multiplier: 50
AVX Offset: -3
XMP: XMP 1 Enabled
MCE: Disabled
Max temp 94c.
