Need help to Overclock my CPU
Bryan K
57
I don't know how to overclock my CPU so my computer stops the freezing with games. I don't want to mess it up to bad but I want it lag free.
Specs: ------------------
System Information
Time of this report: 1/4/2014, 16:29:36
Machine name: BRYAN-DESKTOP
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130828-1532)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: To be filled by O.E.M.
BIOS: BIOS Date: 03/09/12 12:12:36 Ver: 04.06.05
Processor: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz (4 CPUs), ~3.8GHz
Memory: 8192MB RAM
Available OS Memory: 8154MB RAM
Page File: 3675MB used, 20860MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 32bit Unicode
First back up a sec. If your games are "freezing", OCing your CPU won't stop that. Your CPU by itself should be more than capable of playing today's games. What video card are you running? Are you running the built-in video card that came with your PC? If that's the case, then you should consider investing in a newer, mid to high end card so you can play higher settings w/o lagging. Also, keep in mind if the lag only occurs while playing multiplayer games online, there's not much you can do about that.
