Need help to pick internet adapter
BeBlaze
73
4
4,535
I have been looking at the TL-WN881ND i just need to know will it suit for downloading and online games and idk if this is true but i heard that after acouple years or months it will get slower the internet thing i just need to pick out i would like to go for a lilttle low price and i just want it to have antennas not anything else. ohh yea almost forgot will bluetooth work in it?
TL-WN881ND - $18 AUD 'Without postage added'
TL-WDN4800 - $49 AUD 'Without postage added'
We use foxtel internet soo idk if they will go best with that soo yea
Because im 16 and my pc is in my room and im not gonna use ethernet going to the loungroom with dogs and one of my dogs are really scared of cords plus my parents wont like that
You didn't say what WAN speed or what router you have. So telling you to buy the more expensive adapter is of unknown benefit. IF you have a dual band router and the 5Ghz network will get to your room then the more expensive adapter would be better.
BUT, I agree with @SkyNetRising, the you will be much happier with powerline network adapters. I would recommend a slightly different model -- https://www.tp-link.com/au/products/details/cat-18_TL-PA9020P-KIT.html Because the ones I recommend are AV2 (newer standard) certified.
We use foxtel and just did a test on http://www.speedtest.net/#
with a USB internet wifi *that i normaly use for my laptop
WIFI USB: Dual-Band AC1900 USB Wi-Fi Adapter by ASUS
PING ms
DOWNLOAD Mbps
46.11
UPLOAD Mbps
17.74
We have 5gz and 2.4ghz i think so
