Need help to pick most suitable pc case for custom build
Mar 21, 2018
31
Hi guys, I'm a first timer when it comes to building PCs so I'd need some help with picking a case.
Some info about my build:
- core i5 800
- B60M H mobo
- GTX 1060 6GB
- RAM 2x4GB 2400MHz
- 1 HDD 1TB WD 7200RPM
- 1 SSD 250GB
I was thinking of getting 750D Airflow by corsair just because I can get it for quite cheap (I know I don't need that much space). I'm open for alternative options for around 100USD/GBP.
I prefer all aluminum Lian Li cases. Tool-less design, fantastic quality and strength at incredible LIGHT WEIGHT. No sharp edges anywhere! no cut fingers. I have one that is over 10 yrs old and still looks and performs new. well, i need new filters and a couple case fans before it goes back into action.
http://www.lian-li.com/
Motherboards with B60 chipset come in different form factors. Are you planing to get an ATX sized board or a smaller one?
Is an external 5,25" bay a must have in your use case?
Be quiet cases has good air flow and good noise dampening, the SilverStone Kublai KL07 is great in those aspects as well.
Zalman R1 is a budget solution http://zalman.com/contents/products/view.html?no=55
Or you can get a case without external drive bay like the Cooltek NC-01, or Corsair Carbide 100R, be quiet! Pure Base 600, SilentiumPC Gladius M35, Nanoxia deep silence series.
You will find it hard for people to recommend computer cases here. Cases are more personal as not everyone likes the same look.
My last 3 builds have been in Phanteks enthoo pro and eclipse p400 cases. Others i have used are Fractal Design define R5 and Corsair Carbide 200R
the mobo is mATX. Thank you for recommendations
Yeah the cases are personal I know, I'm just looking for some inspiration alongside to see what kind of case I'd like the most. Thank you! :)
