Need help to select a dual monitor stand
Brandonr91
As the title would suggest I am in the market for a dual monitor stand
My requirements are as follows...
Must accommodate two 27' monitors
Must accommodate approx 37 pounds with both monitors mounted.
I would prefer the monitor be on a stand, no clamp / mounting solutions unless you can provide me a product that has a clamp that can accommodate 5 1/2' desk widths..
I need to be able to articulate the monitor
Lastly, I'd like 5-8 inches of space between monitor bottom edge and desk.
My monitors measure 25' in height thus the stand/pole needs to make my monitor bottom edge hover more than 5 inches off the desk.. and this is the main reason I am asking because I am not sure about below monitor clearance and I'd be sorely griefed if I don't have at least this clearance from bottom edge of monitor to desk because I plan to put speaks and lan-ip phone below the monitors and thus de-cramp my desk space.
I am currently considering this product - http://www.amazon.com/Elitech-Aluminum-Monitor-Standing-Adjustable/dp/B00ITW25I6/ref=pd_cp_pc_2 - However, I am unsure of monitor edge to desk clearance.
