Need help to which Sound Card to get
LilHomie13
12
I bought some new speakers (havent arrived yet) Logitech Z-5300 and I want to know what is the best choice from these cards. Audigy 2 ZS, Audigy 2 ZS Gamer, or Audigy 2 ZS Platinum. Thanks in advanced for the help!
the platinum comes with the external 5 1/4" breakout box with midi in/out, spdif in/out, optical in/out, etc. if you dont need the extra connectors in the front there is no point in considering it, because its nearly twice as much as the standard audigy2 zs. the only difference between the gamer and the standard audigy2 zs seems to be two more games included in the gamer, Halo Combat Evolved and Splinter Cell.
