Need Help Troubleshooting Failing Hardware Components
bms85
62
My Build (seen below) Has recently been plagued with failing components. In the last month I've lost a GPU and two SSDs. I Had the SSDs in a raid 0 both times. I had been running the drives for over a year before the first failure. I RMAed the failed drive, rebuilt my raid, then had the new drive fail on me again two weeks later.
I'm not sure if this makes a difference but every failure (GPU and both SSDS) have occurred during a system resume.
Both times i lost an SSD I had full backups of my files, but each time it took out my primary work PC for over a week. I can't help but worry that there is something burning up my hardware. I've build many PCs and haven't had a single hardware failure. Is there something I can run to monitor stats (voltages,temps etc.)? Maybe dump a log to a spare drive?
For reference this is what I'm running:
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115095
GPU: (X2 SLI)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130655
MOBO:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157269
RAM:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
HDD: (2x in raid 0)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820139601
Power:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139014
Thanks for all the replies. PSU testing is straight forward enough. Is there any way to test the MOBO IDE controller? or should I just replace it?
EDIT: Maybe I should also point out I have 4 other drives in this pc that aren't OS drives that have yet to fail. One of them is also a SSD.
