Most mobo's can supply 1A on a fan header. Most fans draw at max rpm about 0.35A. You could run 3 fans off of a header without a problem. To be be on the safe side 2 fans is no issue. 2 of these fans splitters will do the job: https://www.newegg.com/Product/Product.aspx?Item=N82E16812162026&cm_re=PWM_fan_splitter-_-12-162-026-_-Product. I'd suggest the 2 input fans at the front of the case, using 1 header. 2 exhaust fans at the top of the case on a second header and the rear exhaust fan on the third header.
