Question Need help updating BIOS on Gigabyte X870e Aorus Pro Ice
Oct 2, 2024
42
I can't get the system to see the flash drive. It is Fat32, It is in a port on the back of the PC. The extracted BIOS file is on the drive. I boot into BIOS. Go to Qflash, and all that is there is C drive. It doesn't see the USB drive. I have disabled secure boot. I don't know what else to do.
Nevermind, I figured it out. Gigabyte sure doesn't give a whole lot of direction on their website on the easiest way to do this. After 20 min of Google searching I found 5 different ways to do it and eventually got 1 to work. It just seems they could make it a little more straight forward for the people that aren't tech gurus.
Have the same problem so what was the solution?
I'm sorry, its been a while since I did this so I can't exactly remeber which method I used but it seems like I had to rename the BIOs file to some generic name in order for it to be recognized. If you google that you might be able to find it. I'm sorry I can't remember.
Now that I think about iy, it seems like I had to rename it. "gigabyte.bin" Google that witht your problem and see if that comes up.
