Need Help Upgrading First Build
kronogor
67
Hello everyone!
I have been reading articles here ad nauseum and I still can't decide which would be the best upgrades I could make on my PC. When I built it I was on a budget, but now I have the opportunity to get some of those fancier components I wasn't able to purchase during the initial build. The primary purpose of this PC is gaming, and after seeing trailers for many great games coming soon, I would really like to make sure my PC is not only up to the task, but handles it with ease.
Primary Function: Gaming
Budget: $300-400
Components:
CPU: AMD Phenom ll X4-955
CPU Cooling: CoolerMaster Hyper 212+
Motherboard: Gigabyte GA-990XA-UD3
Memory: G-Skill 4GBx2 Ripjaw Series DDR3 1333
GPU: HIS IceQ Turbo Radeon HD 6850 1GB 256bit
Hard Drive: WD Blue Caviar 1TB Sata 6Gbs
Power Supply: Corsair 750W
Resolution: 1920x1080
Right now, I am leaning towards getting another HIS Card so I can crossfire them. However, I don't know if a new CPU will lead to better performance while gaming.
Thank you for your time, and I very much appreciate any suggestions!
Edit: Added resolution and budget
Yes, budget would be useful. Also what is your monitor resolution?
First: Do you need to upgrade it? Are games slow already? If it's doing well enough now then wait until it isn't and then you'll get the newer faster hardware.
But if you need to upgrade, here's some general advice: If that's a BE chip, then OC it. Then go for a new GPU. Again, not knowing your resolution, if it's 1080p then your 6850 is your gaming bottleneck. I would not Xfire the 6850. Not knowing your budget, I can't say for certain but I would buy a 7850 (minimum) or 7870 (or higher) and sell the 6850. If your CPU starts holding you back then upgrade to Vishera and you'll be rocking everything.
larkspur
kronogor
67
Oh I am sorry guys, dumb of me to not post the budget.
Budget: $300-400
Screen Resolution: 1920x1080
As for right now, I do not desperately need to upgrade; games run on High pretty well. I do need to upgrade though, if I want to run these newer games on Ultra & such. However, if I am being silly in wanting to upgrade for no real reason please let me know.
