Question need help upgrading gpu
john3182
Commendable
Nov 11, 2022
9
hi iam runing 2070 at min was thinking off get a 4070 but herd they not that good was looking at 3080 or the 6800 wor the 7900xt thanks you
It's not so much that they aren't good, it's more that they're quite a rip off for what they cost. 3000-series will offer a much better bang-for-buck, and so will AMD's higher end 7000s or 6000s.
I'd suggest looking at this article to know where each card stands, than make your choice based on the prices you find.
hi would there be good jum from the 2070 to the6800 xt or would it beter pay the extra go with 7900 thanks
