Hi my friend has a "Dell XPS One 24" with 2 1g ram sticks. They are getting used up so I told him i'll try to get him 2 2gb sticks since thats the maximum im pretty sure.
I found this info on the pc:
* Module Size: 2GB
* Package: 240-pin DIMM
* Feature: DDR2 PC2-6400
# Chipset: Intel G45
# Maximum Memory: 4096MB
# USB Support: 2.x Compliant
# Standard Memory: 4096MB removable
# Slots: 2 (2 banks of 1)
Each memory slot can hold DDR2 PC2-6400 with a maximum of 2GB per slot.*
^ thats the default so i'm not sure what ram i should get him, but was thinking the 6400 since they are the fastest. Any help is appreciated, thank you!
* Module Size: 2GB
