Need help upgrading my brother cpu
That motherboard is extremely old and does not uses an obsolete socket. What does your brother plan to do with his computer? General use? Video editing? Gaming? And what is your budget. Please provide more information in order for me to help you.
plans to use it for gaming but nothing major at most he will be playing left for dead and team fortress 2, as far as budget goes in the range of 100$. Also, yea his computer is old
Does he have a graphics card? Because it is not possible to upgrade the CPU without upgrading the motherboard. Well it is possible, he can look for a used Core 2 Extreme x6800 but in my opinion it is not worth it. It is better to upgrade the motherboard, but if you change the motherboard you will need to buy new RAM as well and most likely a new PSU. If he does not havea graphics card, buying one will boost the performance.
