Need Help Upgrading My Current Build!!
garrett96kelly
https://pcpartpicker.com/list/yCv2JV
So everything here, minus the CPU (which is currently a i5 6600k) is what is in my current build. I'm looking to upgrade my CPU so i get a little more performance while streaming and gaming on my PC. According to PC Part Picker, is says everything should work, but then at the bottom of the part's list, it says the following:
"Some Intel B150 chipset motherboards may need a BIOS update prior to using Kaby Lake-S CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions."
So does that mean the CPU and my current motherboard won't work together? Or do I have to get a whole new motherboard as well? Thanks for any help in advance!!
parani
756
125
You may need to update the bios to the latest verdion if its not the latest to support the kabylake processor .It will work fine
Also Coffeelake releases on oct 5 so wait and decide
parani
756
125
garrett96kelly
I'm sorry, what does Coffeelake mean? Not very smart when it comes to CPU's. Would you recommend waiting for the "Coffeelake"?
parani
756
125
Its the Intel's upcoming processor .It performs 45% faster than i7 7700k in multi threaded based on the leaked benchmarks .so just couple of days ,i suggest u to wait
garrett96kelly
Oh ok. Would you happen to know what the price difference is gonna be?
