need help upgrading my gaming pc
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($117.97 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.98 @ OutletPC)
Video Card: PowerColor Radeon HD 7870 XT 2GB Video Card ($163.98 @ Newegg)
Power Supply: Rosewill Hive 650W 80+ Bronze Certified Semi-Modular ATX Power Supply ($49.99 @ Newegg)
Total: $361.92
(Generated by PCPartPicker 2013-11-15 20:57 EST-0500)
The 7950 is better than the 7870xt, but I think saving the money to afford a cpu cooler is more...
This is the best i can do dude
PCPartPicker part list: http://pcpartpicker.com/p/22Xj7
Price breakdown by merchant: http://pcpartpicker.com/p/22Xj7/by_merchant/
Benchmarks: http://pcpartpicker.com/p/22Xj7/benchmarks/
CPU: AMD FX-6300 3.5GHz 6-Core Processor ($119.99 @ Newegg)
Motherboard: Asus M5A78L-M LX PLUS Micro ATX AM3+ Motherboard ($44.99 @ Newegg)
Memory: Kingston 4GB (1 x 4GB) DDR3-1600 Memory ($28.77 @ Mac Mall)
Storage: Western Digital RE3 250GB 3.5" 7200RPM Internal Hard Drive ($35.94 @ Amazon)
Video Card: MSI Radeon HD 7850 2GB Video Card ($109.99 @ Newegg)
Case: HEC Enterprise MicroATX Mid Tower Case ($9.99 @ Newegg)
Power Supply: CoolMax 500W 80+ Certified ATX Power Supply ($19.99 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($14.99 @ Newegg)
Total: $403.42
(Generated by PCPartPicker 2013-11-15 20:27 EST-0500)
PCPartPicker part list: http://pcpartpicker.com/p/22XkC
Price breakdown by merchant: http://pcpartpicker.com/p/22XkC/by_merchant/
Benchmarks: http://pcpartpicker.com/p/22XkC/benchmarks/
CPU: AMD FX-6350 3.9GHz 6-Core Processor ($139.99 @ Newegg)
Video Card: Sapphire Radeon HD 7950 3GB Video Card ($195.66 @ Newegg)
Power Supply: Corsair Builder 600W 80+ Bronze Certified ATX Power Supply ($37.99 @ Newegg)
Total: $373.64
HD7870 < HD7950
Ref. http://www.tomshardware.com/reviews/battlefield-4-graphics-card-performance,3634-7.html
Total: $361.92
The 7950 is better than the 7870xt, but I think saving the money to afford a cpu cooler is more important. I'd avoid the Corsair CX series as long as there is something similarly priced that is better, like the Rosewill Hive 650.
Here
http://www.gigabyte.com/products/product-page.aspx?pid=4311#
You can click on the cpu support list and see that it will run an FX 6300 if it has the F5 BIOS .
If you do not already have the F5 BIOS [ check by rebooting and hitting the DEL key to get to BIOS ] you can update it from that page too . Follow the instructions EXACTLY .
You may be able to get a very limited overclock , but that board is not really made for that .
If the psu is 80+ rated you should be fine with that processor and a GTX 760
bios version 2.4 F2, 5/8/2012
When I went to the website they had no updates listed for bios under my motherboards name. I also tried "delete" at start up and was unsuccessful in finding any bios update
