Need help upgrading my graphics card on hp pavilion h9-1110t
durangod
86
I need some help finding a newer upgrade graphics card for my machine. I dont know why but i always get low fps like 20-40 max on games and also when im downloading its hard to surf the web at the same time. Sometimes i dont think i can go any higher but then again i have an i7 and i should be able to. I just dont know enough about this to be able to choose a new card on newegg.
here is my system. I have added an external 1TB hard drive as well as another 500GB internal HD. So i have plenty of space. And i am running dual monitors.
I am also running 12GB of ram.
HP Pavilion HPE h9 Series model h9-1110t
here is my current card
https://www.techpowerup.com/gpudb/392/radeon-hd-7670-oem
my system
http://support.hp.com/us-en/product/HP-Pavilion-HPE-h9-1100-Phoenix-Desktop-PC-series/5154893/model/5193506
here is my motherboard
http://support.hp.com/us-en/product/HP-Pavilion-HPE-h9-1100-Phoenix-Desktop-PC-series/5154893/model/5193506/document/c02854392/
last summer i did accidentally break the little black retaining clip off the card insert on the motherboard but the card is nice and tight and i dont get any errors or issues ever.
Im looking somewhere between $50-$150 bucks budget wise, if its worth it i can go alittle higher but not much maybe 200 max but i would never spend more than that on any card ever, even if it was made out of gold lol...
Also when i ordered this PC in 2012 at the time i used it for more business related but now that i closed my business i do alot of gaming on it. So maybe the specs need adjustment somehow.
Any help would be appreciated, thanks so much...
Dave :)
get The GTX 1060 ... $250 it is worth it ..
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487260&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
If you insist on low budget , get the GTX 960 ... but it is half speed ..
OK thanks so much, ill save up for the 1060 at least that way my machine should not need anything else for quite some time.. Thanks i really do appreciate it. :)
