Hello,
So I've had my PC for over 2 years now, and I'm thinking of upgrading it in the near future. I wanna make sure that it's worth it or should I just buy a new PC.
My specs:
CPU: Inter Core i5 3450 3.1Ghz 6MB L3 Cache s1155
MB: Gigabyte GA-H77-D3H
RAM: G.Skill Ares 2x4GB DDR3 1600Mhz
VGA: Sapphire Radeon HD 7770 GHZ Edition 1GB GDDR5
PS: Antec High Current Gamer 620W
More details in the spoiler below.
http://www.crucial.com/usa/en/scanview/79B8D21C31D926C3
So I'm thinking to add another 8GB RAM which is no problem, but the thing is I want to afford a video card that's worth buying which should be MUCH better than my current one and I mean.. So much better, so I don't feel like I've wasted a little more of a price just to get a slight difference and improvement in performance. I need it BIG. o:
I was looking into a GeForce GTX 980 card, which I can afford. I just wonder if it's compatible with my current PC build.
Also any suggestion for a decent affordable i7 CPU would be great too.
This is the site I use for shopping, http://en.ksp.co.il
But if there's any international site I can buy from other than eBay you can suggest would be much appreciated.
Thank in advance : )
My specs:
Code:
Processor Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz
Manufacturer Intel
Speed 3.5 GHz
Number of Cores 4
CPU ID BFEBFBFF000306A9
Family 06
Model 3A
Stepping 9
Revision 10
Video Card AMD Radeon R7 200 Series
Manufacturer ATI
Chipset AMD Radeon R7 200 Series
Dedicated Memory 1.0 GB
Total Memory 728.1 MB
Pixel Shader Version 5.0
Vertex Shader Version 5.0
Hardware T & L Yes
Vendor ID 1002
Device ID 683D
Plug and Play ID VEN_1002&DEV_683D&SUBSYS_E214174B&REV_00
Driver Version 14.501.1003.0
Memory 8.2 GB
Operating System Microsoft Windows 7 Ultimate Edition (build 7600), 64-bit
Service Pack 0
Size 64 Bit
Edition Ultimate
Version 6.1.7600
Locale 0409
BIOS BIOS Date: 04/09/12 15:24:37 Ver: 04.06.05
Version American Megatrends Inc. F6
Manufacturer American Megatrends Inc.
Date 04/09/12
Display Maximum Resolution 1920 x 1080
Sound Device 1 AMD High Definition Audio Device
Driver Version 7.12.0.7719
Sound Device 2 VIA High Definition Audio
Driver Version 6.0.1.10500
