S sedrik05 Jan 24, 2023 1 0 10 Jan 24, 2023 #1 I'm planning to upgrade my Ryzen 5 2600 to Ryzen 5 5700G. I'm currently using it with RTX 3060Ti. Also, I'm using Corsair VS650 if that's a factor. Thank you.
Kona45primo Honorable Jan 16, 2021 581 173 9,890 Jan 25, 2023 #2 Update your bios and go for it. If you're going to be using the 3060ti as well you can just go for a 5600x/5700x and bump up in performance since you won't need the integrated GPU Upvote 0 Downvote
kurdtnz Honorable Feb 24, 2020 2,223 370 12,640 Jan 25, 2023 #3 What motherboard do you have? Upvote 0 Downvote
DSzymborski Curmudgeon Pursuivant Moderator Nov 19, 2010 21,210 5,332 106,640 Jan 25, 2023 #4 Frankly, I'd replace the entry-level office PSU being used with a 3060 Ti for some odd reason before upgrading the CPU. Upvote 0 Downvote
