[SOLVED] need help upgrading pc
luke1
19
I recently got a new GPU (RTX 2060 Super) for playing games at high graphics with rtx settings but I noticed that I am having performance issues and was wondering what I should upgrade next.
I looked into upgrading my CPU (Xeon E5-1650) because I noticed that playing Cyberpunk 2077 it will commonly reach 100% cpu usage, but I'm not sure what to upgrade to due to the limits of my older motherboard (Supermicro X9SRL-F).
I also have 32gbs of DDR3 ram and running my games on Seagate BarracudaFas 1TB SSD.
Upwards of £800, and I'm in the UK.
If you plan on OC then a Z590 board paired with this cpu.
I'll use this Gigabyte board for an example.
https://www.scan.co.uk/products/gig...-40-sata3-3x-m2-25gbe-ac-bt51-usb-32-gen2-atx
Gigabyte Z590 UD AC £164.99
https://www.scan.co.uk/products/int...eads-36ghz-50ghz-turbo-16mb-cache-125w-retail
Intel Core i7 11700KF £379.99
https://www.scan.co.uk/products/be-...pipes-120mmplus135mm-silent-wings-pwm-fans-al
be quiet! Dark Rock PRO 4 Dual Tower CPU Cooler £74.99
If you don't plan on OC then a B560 board paired with this cpu.
I'll use...
What's your budget and what country are you located?
I'll use this Asus board for an example.
https://www.scan.co.uk/products/asu...-ddr4-pcie-40-sata3-2x-m2-gbe-usb-32-gen2-atx
ASUS PRIME B560-PLUS £119.99
https://www.scan.co.uk/products/int...reads-25ghz-49ghz-turbo-16mb-cache-65w-retail
Intel Core i7 11700F £299.99
https://www.scan.co.uk/products/coo...le-tower-aluminium-fins-4x-copper-heatpipes-i
Cooler Master Hyper 212 Black Edition £32.99
And DDR4 3200MHz CL16 RAM.
https://www.ebuyer.com/743022-corsa...ram-3200mhz-c16-memory-kit-cmk16gx4m2b3200c16
Corsair Vengeance 16GB (2x8GB) DDR4 3200MHz C16 Memory Kit £78.98
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor (£329.99 @ AWD-IT)
CPU Cooler: Noctua NH-U12S SE-AM4 CPU Cooler (£53.79 @ Amazon UK)
Motherboard: MSI MAG B550 TOMAHAWK ATX AM4 Motherboard (£155.99 @ Amazon UK)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory (£207.76 @ Newegg UK)
Total: £747.53
Generated by PCPartPicker 2021-04-04 22:07 BST+0100
You can certainly go with a new mobo/cpu/ram as has been suggested.
Perhaps spent a little time stopping unneeded stuff from running in the background before running your games......it's free.
