Need help upgrading some parts
ellman12
Commendable
Oct 17, 2016
159
Hello,
I got a new computer a while ago, and I noticed that the power supply was some cheap 800 watt noname PSU. I would like to get a newer and higher quality one. I appreciate any recommendations. I have a gtx 1080 and an i7 6700k.
Also, I would like some more and better fans. I would appreciate any recommendations as well.
This is my case: http://www.honbontec.com/turbine700_product.html
Also, should I get this? http://
Thanks for any help.
Usually, I like to stick with psu's from Corsair, evga. A lot of guys say seasonic is good. Look for something of a good brand like those, and a lot of amps on a single 12 volt rail.
Fans there are many options. I like to look for the cheapest with the highest cfm airflow numbers I can. But a lot of folks like noctua and Corsair fans if you are looking for quiet fans with good airflow, but they can get pricey.
