Question Need help urgently pc wont start
adast
366
Hello all after a long time just today I opened pc to clean it I just took cpu out put new thermal paste putted back and now my pc just starts it turns on for like 20 or 30 seconds and it turns off and it keeps doing that but there is no display aswell all fans running gpu aswell power supply what I noticed there is bend on motherboard where I put cpu just one pin could be that a problem??
adast
366
hell yeah.Can you list full pc specs,including motherboard and psu.
I5 6600k
Gtx 970 4gb
16gb ram
gigabyte h110m-s2h
1tb ssd
1tb hdd
Psu game max 500w 80bronze
I was using today pc I played but after I took out cpu thats it and as I said I can see slightly in motherboard there is bend pin
adast
366
you will need a new mobo.I have personally broken/bent some pins and its a real pain on a intel motherboard.With the ryzen chips its much easier to fix.Shame u could fix it
Any recommendations for new motherboard with cpu but not expensive as later on im planning to buy rtx gpu
Dec 6, 2020
12
Yah you can use rtx in 3600/3600x cpu and also with these mobo. If you can increase budget then go for ryzen 7 3700x. But 3600 is enough. 3600 might require a decent cpu cooler. Cz it's temperature reaches 70+ with stock cooler while gaming.
U can run ur ram at 3200mhz in these CPUs.
Dec 6, 2020
12
Ryzen CPUs are good for multitasking. Like if u play games and stream same time. Ryzen will perform better. You can use ram at 3200 mzh frequency. U don't have to change mobo everytime you switch cpu. This mobo can support all ryzen cpu and also have pcie 4.0
Just seach on Google "Ryzen 5 3600 vs i5 10400f"
And the 10400f wins.No point in getting ryzen for him since the 3600 alone is near 200$ and what is the point with going with 3600 if you not going with b450 board,which is another 100$+.If ur doing just gaming 10400f is 10% better than the 3600/x,in any other task like editing and that sort of stuff,ye ryzen is better,but for just gaming you gotta go with the 10400f.
Reactions: adast
