Hi ,
I just built a new pc
Everything set up (i built about 9 PCs and everyone is working fine)
Components:
MDB Asrock h110m DVS 2.0 (used 2 months with an i5 6600k , working perfectly on my pc in the day i swaped it to the new case)
CPU i3 7100 with stock cooler (brand new , sealed)
HDD Toshiba 7200 rpm 32mb cache 1TB (brand new , sealed)
PSU 500 W Intertech (brand new , sealed)
RAM Kingston CL15 4Gb 2133mhz (brand new , sealed)
The problem is that the PC is restarting (after 10 seconds) and No signal on the monitor.
I cant enter the bios cant install windows.
Things i've tried without succes :
- ejected the battery from motherboard for 1 minute and put it back
- changed PSU with my PSU (that used to supply the mdb before and was working)
- changed the ram slot and ram memory with a HyperX Fury 8gb 2133
- powered on without the HDD connected to the PSU and MDB
- powered on with only the CPU and PSU connected
- disconnected the power cable and hold the power button for 1 minute then tried to power it back on
- changed 3 monitors and changed signal source (DVI or VGA)
- tried to plug an external GPU (1050 TI)
All things possible ... but still no result !!!!!!!!!!
Can someone help me ? I'm out of any ideas 🙁(
I need an answed ASAP , its the 3rd day im trying things and my father in law is kinda going mad .... HELP !!!!
Components:
