need help which computer should I get? (gaming ultra settings 60fps +)
FragaZ
30
http://pcpartpicker.com/p/jKrksY <---- this one?
http://newbcomputerbuild.com/newb-computer-build-home/february-2016-monthly-gaming-pc-builds/#1000-pc-build <---- the $1000 one (which graphic card too)
http://newbcomputerbuild.com/newb-computer-build-home/march-2016-gaming-pc-builds-month/
<--- again go down to the $1000 one.
https://www.youtube.com/watch?v=dbvbSfyCx2E <--- or this one
Thanks inadvanced for all the people who will answer me. this computers are meant for gaming/videos and if you guys have any better builds for 1000 dollars I'll happily check them out!
CPU: Intel Core i5-4690K 3.5GHz Quad-Core OEM/Tray Processor ($219.99 @ SuperBiiz)
CPU Cooler: RAIJINTEK THEMIS Evo 65.7 CFM Sleeve Bearing CPU Cooler ($29.99 @ Newegg)
Motherboard: ASRock Fatal1ty Z97 Killer ATX LGA1150 Motherboard ($92.98 @ Newegg)
Memory: A-Data XPG V1.0 16GB (2 x 8GB) DDR3-1600 Memory ($62.38 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($86.75 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.89 @ OutletPC)
Video Card: Gigabyte Radeon R9 390X 8GB Video Card ($378.98 @ Newegg)
Case: Deepcool KENDOMEN Black ATX Mid Tower Case ($57.98 @ Newegg)
Power Supply: EVGA 650W 80+ Gold Certified Semi-Modular ATX Power Supply ($69.99 @ Amazon)
Total: $1048.93
Generated by PCPartPicker 2016-03-10 12:42 EST-0500
Job done
Is this one any good?
Case – Corsair Carbide Series Black 300R Mid-Tower
Processor – Intel Core i7-4790K Quad-
Motherboard – MSI ATX Z97 DDR3 2400 LGA 1150
Video Card – Gigabyte GeForce GTX 970 G1 4GB
RAM – Crucial 8GB Single
Power Supply – EVGA SuperNOVA 750W B1 80+ BRONZE
Hard Drive – Seagate 1TB Desktop HDD SATA 6Gb/s 64MB Cache
CD Drive – Asus 24x DVD-RW
decent - are you actually looking at building your own or are these listings for prebuild sites ??
If you are building your own then the partpicker list I dropped in is about the best you can possibly do for the money with zero weak components at all.
You keep obsessing with an i7 but for $100 extra its just plainly not worth it for primarily a gaming build - there is zero performance increase.
so the one you posted is better than the one I posted? if so. do you think I should get the one you posted for high-end gaming? (obviously in my price range)
Better in the sense that it includes a stronger gpu,16gb ram ,a very good aftermarket cooler,a 250gb ssd (one of the best around) & a better quality psu.
better value?? I dont know as you havent put a price to your last build.
Better performing,better quality,& better value than that $1050 build you posted earlier?? yes absolutely 100%
better.
Oh that last build is a grand??
yes the partpicker one I posted is absolutely worth the $50 more (for the above reasons)
Dropping that i7 to the i5 makes a massive difference to the rest of the components in the same price range for the total build cost.
