Question Need help which monitor to get
Welshboyjoe11
Commendable
Mar 15, 2017
hello from the uk so £350 is my max point and so far i got two monitors i can choose from one being:
ASUS VG278QR 27 inch, 165hz & 0.5 ms
TN panel
https://www.amazon.co.uk/ASUS-27-inch-Monitor-FreeSync-Certified/dp/B07KKBDQCL/ref=sr_1_7?crid=3H0DI8I3YRK44&keywords=gsync+144hz+monitor&qid=1578520356&sprefix=gsyn,aps,140&sr=8-7&th=1
OR
BENQ ZOWIE XL2540 24.5 inch , 240hz & 1 ms
LCD/LED Panel
https://www.amazon.co.uk/dp/B01M9GRZQA?tag=pcp0f-21&linkCode=ogi&th=1&psc=1
I play competitive gaming only at 1080p
I currently have a ASUS VG248QE
If any other suggestion on other monitors please note name or a link
Newtonius
Respectable
If you don't mind washed out colors and low viewing angles, then that ASUS TN panel option is the way to go, the refresh rate and screen size is ideal for competitive gaming. The BENQ monitor has a really good refresh rate but honestly 144Hz - 165Hz is all you really need, plus that listing doesn't give any other specifications about its features, a little sketchy to me.
If you do mind colors and want a better viewing angle (the angle at which colors start to fade/discolor) then a VA panel type monitor would be best for you then.
