Need Help, will this Graphic Card fit onto my motherboard?
iGouldy
31
Hello, i'm currently in a bit of a jam and could be doing with some help, i currently have a MSI FM2-A55M-E33 Motherboard and i'm looking for a graphics card. However this is where i'm having trouble, the way in which my motherboard is designed all the SATA ports are directly below the PCIe Port. The graphics card that i like the look of is an Asus Nvidia Geforce GTX 750 Ti, its fairly large and this is what is causing me bother. Anyone got this motherboard and if so would this graphics card fit. Thanks for your Help guys really appreciate it!!
Im thinking about buying L-shaped SATA wires, to make it a little easier to connect
I use those in my build, they seem to help a little with space management
Thanks For the Help Guys really appreciate it, i just found a much smaller version of this card so i think i will play it safe and get that one, once again thanks alot
